jjrbus
Oct 15, 2019Explorer
Depends on the sensors you have for the tank. If they are in tank contacts anytime solids or paper hangs up on them they will show the tank is full. You can use every magic elixir, snake oil, spray accessory know to man and the monitor will work until something hangs up on the sensor again. Which usually does not take very long.
To save some long term aggravation, turn off the pump, push flush lever and look in toilet with flashlight, what you should see is black water tank level. Flashlight held up to fresh water tank will also show level.
If you have external sensors, usually a strip of what looks like foil, then you have another problem. If you wish to add external sensors look up Seelevel tank monitors.
38,782 PostsLatest Activity: Aug 23, 2026
