Sabretooth
Aug 14, 2014Explorer
Topping up Engine Oil ?
Ok checking my engine oil today, I needed to add 1/2 qt. The only way I could do this was by lifting the bed and topping it up via the filler cap ?
Then I have to close the bed, start the engine and recheck the oil level outside. Luckily I put the right amount in the first time. But is there any way you can top off the oil via the dip stick tube? Or a modification I can do to stop the laborious task of in and out and raising the bed?
I can top off the transmission via the dip stick. which is a lot easier.
My coach is a 1992 Gulf Stream DP with a 5.9 Cummins and the radiator transmission cooler are at the back so vision of the engine is restricted.
Appreciate any advise from others whom have over come the problem.
Thank you
Thank you
