- notevenExplorer III
7ofus wrote:
10forty2 wrote:
Torque - What you feel in the seat of your pants when you push down on the pedal from a dead stop.
Horsepower - Something that gearheads measure to make themselves feel better...... ;-)
So according to this logic, drag racers should all convert over to diesel engines if they want an advantage:)
You don't think a big block gas/alchohol/nitro drag engine has much torque? - Cloud_DancerExplorer III care about the torque and HP curves in the turbo'd 8.3 Cummins diesel engine that's in the back of my motorhome. When I ordered it, I made sure that these curves were matched to the gear ratios, rolling tire radius, and weight. If only the roof design had been this good.
- DSDP_DonExplorerOkay....It's been a month or two since the Torque/HP discussion has occurred. :)
I predict 10, no, make that 11 pages before it slows down! :Z - RCMAN46Explorer
427435 wrote:
JetAonly wrote:
The essence of the difference between Gas and Diesel experience is this. The HP and torque curves of the gas engine are shaped the same, they just peak at different RPM's. The diesel has a torque peak early then falls off slowly with rpm, while the HP curve is more peaked at the upper limit of rpm. Since HP is a RPM based measure, as rpm drops HP falls. In a gas engine it may have to fall 1500 rpm to see the torque rise. In a diesel the torque rise is immediate. So, measured HP falls at slower rate in the diesel vs gas.
YMMV
Actually, the curves are not similarly shaped with today's turbo, intercooled, and computer controlled diesels. Their torque curves are flatter and longer. Also, the diesel's hp curve will often grow as the rpm's are lowered.
You need to take a look at the HO 6.7 Cummins. The tongue curve is no longer flat as with the older 5.9.
The Ford Ecoboost gas engine has a flatter torque curve than the HO 6.7 Cummins. - holstein13Explorer IILet's try another analogy. Imagine a stopped bicycle with the pedals horizontal to the ground. Now imagine putting the brakes on and standing on the pedal in an attempt to move the bike forward. The amount of force you apply on the pedal is called torque. The heavier you are, the more torque you can apply on that pedal.
Now for those of you who think torque gets you up the mountain. I'd like to challenge you to get a 250 pound athlete with more torque to compete against a 150 pound athlete with less torque on a similar bike. The lighter athlete will have two advantages, 1) they are lighter and will require less work to get up the mountain and 2) they can turn the pedals faster than the heavier athlete because their legs also weigh less. - 7ofusExplorer
So according to this logic, drag racers should all convert over to diesel engines if they want an advantage:) - 427435Explorer
YMMV
Actually, the curves are not similarly shaped with today's turbo, intercooled, and computer controlled diesels. Their torque curves are flatter and longer. Also, the diesel's hp curve will often grow as the rpm's are lowered. - rgatijnet1Explorer IIIGetting up the hill faster also has a lot to do with the gear ratio of your differential and transmission.
You can have high HP and gobs of torque, but if the coach is not geared right, you will still be heading up the hill in the right lane. Your engine won't be straining, but you are still going slower than if things were set up right, like most over the road rigs are set up that travel the mountains on a regular basis. - 10forty2ExplorerTorque - What you feel in the seat of your pants when you push down on the pedal from a dead stop.
Horsepower - Something that gearheads measure to make themselves feel better...... ;-) - JetAonlyExplorerSince a diesel has higher compression, it must also have a longer strike to make that happen. Longer stroke engines make higher revs hard on the moving parts, specifically the crank shaft. The physics of all this is pretty straight forward. HP is a time rate measure, torque is a force. Torque is a force. Force over distance is work. Work over time is Power, as in Horse power.
YMMV
38,774 PostsLatest Activity: Apr 26, 2026
