Is there any set time limit on when you should send a tow bar back to the manufacture to have it check out even if you are not having any trouble with it? Thanks for any and all comments
I was told at the Blue Ox factory by a tech that you should keep all the joints lubed and tight.. If there's play there's wear.. He gave me a hand full of the nylon washers that are used in the joints and said to replace them as they show wear.. Ours is 8 years old and about 50,000 miles of towing, still looks and feels good.. Mike Mathews..
