PastorCharlie wrote:
jerseyjim wrote:
IF you can tow 4-down, forget the dolly. 4-down is easier and cheaper. What you need is a baseplate and towbar. More than one company makes them...I use BlueOx for my baseplate and Roadmaster for my towbar. Then you have a choice of using magnetic lights or a diode kit for your toads' brake and marker lights.
I would suggest you not doing it yourself...at least this time. Check with an RV dealer or Camping World. Most likely under $1500 for everything.
IMO with your motorhome and the weight of the Ford Fusion, one of those "aux. braking systems" are not needed at all. But that's MY opinion.
Most all states require a braking system.... the MH will probably stop it on normal terrain but the LE will also stop it and give an invite to their justice center.
I hear this a lot on this forum that law enforcement will fine you etc etc. I would love to hear one documented instance where a MH was stopped pulling a toad simply to validate they had supplimental brakes. It's not required in a lot of states, hence why they manufacture and sell tow devices without them. You guys crack me up. Good idea? depends on your setup. Required? depends on state and set up.
http://www.brakebuddy.com/Towing-Laws
This has been beat to death on here, but these people are lying to you. The weights they are giving in these charts are for towing a trailer and even in some cases they have those wrong. For example in California you have to have brakes on a camping trailer that weighs more than 1500 pounds, but for any other trailer you can go up to 3000 pounds before it has to have brakes. A towed motor vehicle is not a trailer under California law and has braking performance requirements, and not a weight limit requirement. The people at Brake Buddy that put this chart together have probably received a million emails from people telling them this, but for some reason they chose to lie to you. I would have no problem if they want to say you should have the braking system, but I do object to them lying to you can tell you it's required my law when it is not.
