FLHTCI's avatar
FLHTCI
Tow hall mode
Greetings all,
I pulled the trigger on a Winnebago Itasca Sunstar 30T.
The previous owner drove it always in Tow Hall mode. Is this a wise decision??
I assume I should only use the tow mode when pulling my Jeep or my Harley trike trailer?
Thank you
  • I usually use it when I'm towing our boat/atvs/jeep, I also use it when I'm in the mountains even if I'm not towing. I also find it helpful if I'm in traffic and want a bit more stopping power to help with the people that pull in front of me.
  • Do you mean tow/ HAUL mode? The Ford is equipped with a tow/haul mode feature that's very helpful when towing and especially helpful on descents. When in tow/haul mode you can tap the brakes on a descent and it will act similar to an engine brake allowing you to use less brakes and over heating them. In our previous MH, I found it helpful even when not towing in stop and go traffic as it changes the shift modes and helps slow you down without a lot of braking. But the tow/haul mode is designed exactly for towing.
