enblethen
Aug 31, 2021Nomad
Whether the frame was extended would be determined by the length of the MH. Some do not have frames extended where long ones do. You can look at the frame to determine if has been. Frames on some rigs are extended using a butt weld where others are plated at the joint adding strength.
