wa8yxm
May 27, 2013Explorer III
What are you using for the aux brake system.. The US-Gear Unified Brake Decelerator system includes a link between the coach battery (Chassis) and the towed, Heavy wire breakerd at 20 amps (Coach) and 40 (Towed).
Invisible brake (Roadmaster?) also has a charge provision.
The Towed charge system above with other brake systemns.
Second, there should be a fuse or two you pull, or you remove the fuse, install a way overpriced adapter (like 50 bucks) with leads and a switch, and plug the fuse into the adapter.. Flip the switch and it cust off the battery killers.
The running lights should NOT come on in the accessory position.
38,769 PostsLatest Activity: Apr 24, 2002
