2ndhom
May 27, 2013Explorer
Do you have an electrical pigtail that goes from the coach to the toad .... most coaches do. There should be a "HOT" terminal. From the toad inlet socket run a # 10 wire to the battery using an alligator clamp at the battery side. Also solder in a diode so the power only goes in one direction .... from coach to toad. This will keep the battery charged.
38,769 PostsLatest Activity: Apr 04, 2026
