nemo45
May 27, 2013Explorer
wa8yxm wrote:
What are you using for the aux brake system.. The US-Gear Unified Brake Decelerator system includes a link between the coach battery (Chassis) and the towed, Heavy wire breakerd at 20 amps (Coach) and 40 (Towed).
Invisible brake (Roadmaster?) also has a charge provision.
The Towed charge system above with other brake systemns.
Second, there should be a fuse or two you pull, or you remove the fuse, install a way overpriced adapter (like 50 bucks) with leads and a switch, and plug the fuse into the adapter.. Flip the switch and it cust off the battery killers.
The running lights should NOT come on in the accessory position.
If you look in your owners manual, it will tell you which fuse to pull, anyway it does on the newer ones. I installed the switch on my Equinox, which I agree was way over priced. But, it may be the best money I've ever wasted. This poster is right, though, the outside running lights should not be on with the ignition switch in the aux. position. I have a friend who has a 2012 Honda CRV and he refuses to pull the fuse like his manual says, but he does make sure his radio is off, and he doesn't seem to have any problems. If it was me, I'd put in the overpriced switch, which you could probably make yourself, if you saw one.
38,769 PostsLatest Activity: Apr 24, 2002
