Mr_Mark1
May 30, 2013Explorer
merleandbabe wrote:
Flat towing a 2007 Honda Civic, with no problems except one.
The running lights stay on and the battery goes dead after about two hours.
Any ideas..on how to prevent this? The ignition must stay in accessories potion, and in neutral.
I have heard of a tow charge? How much
Thank you
Merleandbabe, if your running lights are on you have the ignition switch turned one notch too many. With the key in the 'off' position, slowly turn it just one notch. You should be in the accessory position with no running lights.
Good luck,
MM.
38,769 PostsLatest Activity: Apr 24, 2002
