Lobstah
May 31, 2013Explorer
As mentioned above...pull the fuse. There are "inline switches" available online that allow you to pull the fuse and replace it with a circuit that has a switch and an inline fuse. You can mount the switch anywhere under the dash. When you want to tow, either pull your existing fuse, or upgrade to the switch and just flip the switch. That kills power to your dash/ignition/etc, but will leave your clock and radio alone.
Jim
Jim
38,769 PostsLatest Activity: Apr 24, 2002
