skipngail's avatar
skipngail
towing a vehicle
I have a class a 28foot v10 Ford 2002. I am looking for information on what is the best way to pull a vehicle on all fours. On a dolly. Or on a trailer . Want to know about what kind of car can and can't be towed ....
  • IMO, there is no "best", there is only what you like!
    For instance, I use a fixed arm adjustable width $145 towbar on my Jeep. It has worked great for nearly 20 years on various vehicles. Nothing has worn out, bent or broke! SOME people say it is too inconvenient to use one of the awful things!
    I have no trouble at all. I even hook it to the motorhome by myself!
    I use a dolly for our PT Cruiser. Oh, sure, I could put a lube pump on it. That would only cost about $1000, plus the cost of a towbar and base plates. If it failed, a new transmission would only cost about $2500. I think I'll keep using the dolly. It worked fine for our vacation from Montana to Tennessee and back.
    I have used a trailer also. It works for ANY vehicle. Some vehicles can not be towed four down, and some can not be dolly towed. ALL vehicles within the weight limits can be trailered!
    As for what can be towed:
    Nearly all Jeep 4X4s can be towed four down, as well as many other 4X4 vehicles that have a NEUTRAL in the transfer case shifter. Most 4X4s can not be dolly towed!
    Subaru vehicles, MANUAL transmission only, can usually be towed four down. they can not be dolly towed, regardless of transmission.
    Many front wheel drive manual transmission vehicles can be towed four down. They also make great dolly tows.
    ALWAYS look in the Owners Manual for "Recreational Towing" Instructions for any vehicle you are considering. If the Owners Manual says NO, I would not tow it. Do not rely on what a salesman or service manager says. It is doubtful they really know anything about it!
    However, some people DO tow vehicles that the manufacturer says NO for. It is their vehicle, not mine, I don't care what they do.
    Again, it is personal preference. Only YOU can decide what is right for YOU.
    Good luck.
    EDIT: I forgot to mention towed vehicle braking. While it is a good idea, it is not required by law in many (if not most) states. Some states have "Braking Performance Laws", where you must be able to stop within a set distance, often 40 or 45 feet, from 20 MPH, on a hard, level, clean surface.
    Keep in mind that a towed motor vehicle is often NOT a trailer by legal definition, and trailer towing laws do not apply.
    Check the laws in YOUR state to find out what YOU need to do. Do NOT rely on any list of towing laws on the internet. Every one I have seen is inaccurate!
  • My towing preference is a dolly because with a very light vehicle, it keeps things simple. I have a tiny Toyota Yaris that is a stick shift (standard). Even though it can tow 4 down (and I have towed it this way), I just don't think I can beat the dolly.
    I pull up the dolly, strap the wheels, magnet the lights, and off I go. (well a little more but that's the gist of it LOL)
    I don't even bother with car brakes because it is so incredibly light. Once I'm at a CG or national forest, I get great gas mileage, ease of traveling in mountains, and a super fun car to drive. (of course, this is opinion).
    I DO like the ease of the dolly more than hooking up brakes. etc. Honestly, I was considering getting a landscape trailer with a long ramp and just pulling up on that. Then I wouldn't even have to strap wheels. Just leave in gear, clutch up, with emergency brake on.
  • particularly if you are going to get a car that can be towed, 4 down is best by far. Ford chassis A's will have a tow rating of 3500-5000 pounds. A trailer will wieght the better part of a ton emptry, and when you get there you gotta find a place to put it. Ditto for the dolly, 'cept it's not as big.
    4 down is easy, all you need is a tow bar, lights, and a braking system.Hookup is fast, and there is nothing to store, the tow bar stays on the back of the motorhome when not in use.
    Many if not most 4wd vehicles can be towed. A lot of maunaul trans cars can be too. motorhome magazine has a full list on their website.
    Always check the car's owners manual under "rectreational towing"
    Popular include most jeeps, honda crv's, awd ford escapes, and many saturn models.
    The ever popular searching on this and other forums will yeild a host of info.
