johntank wrote:
GottaRunGottaCamp wrote:
Ivylog wrote:
1800 lbs that far back is going to put 2500+ lbs on your rear axle and take 700 off the front = NO WAY is this going to work. They make toe dollies that you can put the cycle in front of the car.
Like Ivylog said;
I hope you never have any t-case problems as Jeep per the owners manual does not recommend towing a Jeep with 2 wheels off the ground, it's either a 4 wheel flat tow or on a trailer. Just for your information
If he removes the rear driveshaft, the Jeep is good to go.
