Hello, I plan to flat tow my 08 Wrangler 2door with a 96 ITASCA 34RQ with a Ford 460. Has anyone done this and what should I expect. I'm a little concerned of straining the engine. I have a roadmaster...
the capacity of the hitch/receiver should be stamped on it. since that is the old ford chassis, might be limited to 3,500 lbs.? you can probably find a spec sheet for that motorhome on the web. did they add a tag axle on a 34 footer back then? how much was the frame extended? bumpy
