IB853347201's avatar
IB853347201
Nomad II
Apr 12, 2026
Solved
Towing lights issue
Have a 2010 Suncruiser 37j on a Workhorse W22 gas chassis. Power to the 7 pin trailer towing plug receptacle has quit. Anyone know where the fuses are to this? Have checked the main fuse block panel ...
  • IB853347201's avatar
    IB853347201
    Apr 15, 2026
    Well I followed all the suggestions and thoughts shared by everyone on this post and Voila! Issue resolved. Turns out that the issue was caused by severely corroded terminals in the 7 pin receptacle. I used a multimeter and found that the pins were live although tricky to connect to. After using some contact cleaner and a fuse cleaning file, everything works like new.
    Again, thank you all for your help with my issue.
