NeverHome2
Sep 22, 2015Explorer
You didn't say what model your HR was so I don't know if it has a tag axle or not. In any case any DP with a lot of tongue weight will handle badly because the engine and trans. already are cantilevered behind the rear axle.
The added weight causes the rear axle to go temporarily go out of alignment and steers the coach out of straight. You will need to strengthen the suspension trailing arms to fix this. Good luck.
