mattdenryter wrote:
That is why I was asking, if I stay under the GCWR of the MH with the 5000lb boat would I be ok? The dry weight of the MH is 14120, the GCWR is 21000, so a difference of 6880, so minus 5000 for the boat leaves 1880 in cargo and gas in the MH. If I stayed at or under the 21000, would I be ok?
it's the wet weight you should be considering, that's assuning you want to tow the boat while using the RV for it's intended purpose.
the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR minus
the actual weight of the MH as it is loaded for travel (food, fuel, water, LP, clothing, supplies, pets, people and misc. stuff); OR
- the weight rating of the MH hitch (Class II 3500-lbs, Class III 5000-lbs, Class IV 10,000-lbs); OR
- the weight rating of your towbar
load up the MH as you would for travel and then get individual axle weights at a certified scale. compare those axle weights to the published gross axle weight rating (GAWR) for that motorhome. the actual axle weight must be less than/equal to the rating for that axle. add the two axle weights to arrive at the total rolling weight and then apply the three conditions above. assume nothing.
as others have pointed out simply changing the hitch is not enough. you need to speak with someone about that who has no financial interest in the answer one way or another. i'd start with the mfg of your MH and see what they have to say.
