wantingtogo's avatar
wantingtogo
towing with Ford V10
We have a 31 foot Class C. We tow a Jeep Wrangler. We only get 6 mpg. We're feeling we do not have enough power. Also, when we unhook, we're having difficulty getting the jeep back into gear. Is anyone else having those problems? Any suggestions.
  • A couple thoughts. The Ford V10 is a revving motor. In the rev department its more like a Honda than it is a typical burbling Ford V8. Let the engine spin up - it was designed to run that way. Also, w/ the gearing of the rear axle its made more for getting going from a stop than it is pulling you into your seat when you're already moving. The Ford E450 is rated to 22000 pounds GCVWR - it will handle what you're pulling.
    You might want to run it w/ the Tow/Haul mode on and see how it works for you. Many would already consider the chassis 'hauling' once it has a house dropped on it. Add towing - you're just adding more of everything.
