msmith1199
Aug 13, 2015Explorer II
Below are the applicable laws edited to only include what's relevant:
316.261?Brake equipment required.—Every motor vehicle, trailer, semitrailer, and pole trailer, and any combination of such vehicles, operating upon a highway within this state shall be equipped with brakes in compliance with the requirements of this chapter.
2.?The combination of vehicles, consisting of the towing vehicle and its total towed load, is capable of complying with the performance requirements of s. 316.262.
c.?Any vehicle being towed in driveaway or towaway operations, provided the combination of vehicles is capable of complying with the performance requirements of s. 316.262.
The above refers to 316.262 and this is what that says:
316.262?Performance ability of motor vehicle brakes.—
1.?Every motor vehicle and combination of vehicles, at all times and under all conditions of loading, upon application of the service brake, shall be capable of:
a.?Developing a braking force that is not less than the percentage of its gross weight tabulated herein for its classification;
b.?Decelerating to a stop from not more than 20 miles per hour at not less than the feet per second per second tabulated herein for its classification; and
c.?Stopping from a speed of 20 miles per hour in not more than the distance tabulated herein for its classification, such distance to be measured from the point at which movement of the service brake pedal or control begins.
2.?Tests for deceleration and stopping distance shall be made on a substantially level (not to exceed plus or minus 1 percent grade), dry, smooth, hard surface that is free from loose material.
And then the chart is in the statute under this but it won't cut and paste easy.
And I can't find a Florida law definition for Drive away-Tow away operation, but this is a standard legal definition:
According to 49 CFR 390.5 Title 49 – Transportation; Subtitle B -- Other Regulations Relating to Transportation; Chapter III -- Federal Motor Carrier Safety Administration, Department of Transportation; Subchapter B -- Federal Motor Carrier Safety Regulations; Part 390 -- Federal Motor Carrier Safety Regulations; General; Subpart A -- General Applicability and Definitions, driveaway-towaway operation means “an operation in which an empty or unladen motor vehicle with one or more sets of wheels on the surface of the roadway is being transported:
(1) Between vehicle manufacturer's facilities;
(2) Between a vehicle manufacturer and a dealership or purchaser;
(3) Between a dealership, or other entity selling or leasing the vehicle, and a purchaser or lessee;
(4) To a motor carrier's terminal or repair facility for the repair of disabling damage (as defined in § 390.5) following a crash; or
(5) To a motor carrier's terminal or repair facility for repairs associated with the failure of a vehicle component or system; or
(6) By means of a saddle-mount or tow-bar.”
38,782 PostsLatest Activity: Sep 10, 2026
