I have seen a few post on the toyos. I am a fan of toyos but I noticed this new set I have says 125psi cold. But the dealer only put about 95psi? What should I run in them to get the best performance?...
The sticker besides the driver’s seat is the psi IF the axle is loaded to its MAX… go weigh and set accordingly. While the OP may weigh close to the max on the front and assuming a tag the 6 on the rear will be less than 100 psi.
