rgatijnet1
Aug 11, 2018Explorer III
That sounds about normal for Summer temperature increases in hot weather. As long as you set the base tire pressure per the WEIGHT of your coach by the scales, when fully loaded, plus the 5 pounds, you should be fine.
If you go to your tire manufacturer's website they probably talk all about pressure increases due to temperature.
38,766 PostsLatest Activity: Jan 10, 2026
