CapriRacer
Aug 12, 2018Explorer II
To my eye, the pressure build up seems a bit high. I'd recommend using 10 psi higher.
Rule of thumb:
A properly inflated tire will have a pressure buildup of no more than 10%. If the tire reaches 15%, take immediate action - slow down. Then use a higher starting pressure or a tire with more load carrying capacity. If the pressure build up is between 10% and 15%, then something needs to be done, but it doesn't have to be right now!
Rule of thumb:
38,766 PostsLatest Activity: Jan 10, 2026
