wolfe10
Aug 13, 2018Explorer
William B wrote:2oldman wrote:wolfe10 wrote:Max capacity. But folks on here put more air in ??
The sidewall information tell you how much air is required to carry XX pounds (the load capacity of the tire).
No I don't think so. The pressure on the side of the tire is the max to carry the rated load capacity of the tire. Most folks end up with lower than that number. You shouldn't exceed the sidewall number cold.
Correct.
Only reason to consider (improperly) doing this is that the actual weight exceeds tire capacity. If that is the case more air is NOT the answer. Selecting a tire with a higher load range IS the answer.
38,766 PostsLatest Activity: Jan 10, 2026
