Hi Dutch... I pretty much agree with you on all points with the exception of "most economical". The MOST economical would be to tap into the dash indicator for a TPMS fault, wire it into an unused terminal on my connector, and rig up an LED for the coach dash. Total cost about 5 bucks in wire and LED if there's enough amperage coming through to light the additional LED. If not, then I'd need to add a couple more bucks for a small relay.
Four extra sensors (that don't interfere with existing factory TPMS) would cost me 150 bucks according to the big RV supply house. Since I don't already have TPMS on my coach (1999), I would also need to add another 250 bucks or so.
So it's kinda no contendre' on that front.
The other obstacles you bring up can most likely be overcome without a great amount of difficulty. For example... since deciding to change gears on this I've learned a little more about the specific system used on PT Cruisers:
1. Only used on Cruiser years 2008-2010.
2. It's a VDO system.
3. Valve stem type sensor/sender.
4. Transmits data to the tire pressure monitor WCM and EVIC
5. Is a simple unit, not differentiating one wheel from another.
and, a GREAT general description on the overall operation of this unit:
"The PT Cruiser’s tire pressure monitoring system (TPMS) is unusual in that it does not specify how many tires are low or where they are located.
The TPMS consists of sensors that are attached to each wheel through the valve stem mounting hole, a central receiver module (CRM) and an indicator lamp.
The CRM also can include a Remote Keyless Entry (RKE) receiver, Remote Start and the Sentry Key Immobilizer (SKIM) receiver. All receivers share a number of components.
The CRM decodes the signals sent by each tire pressure sensor. The data is used to determine if a “warning” or “fault” condition exists within the TPMS. Transmissions occur once every minute at speeds of 15 miles per hour or higher.
If the TPMS detects that pressure in any tire has fallen, the indicator lamp will illuminate."
So... if I wanted a bit more sophistication, I would shop a scrap yard for a junk wireless control module to install into the coach. The only required connectors SHOULD be power, ground, and dash light output. The unit itself would automatically synch with the Cruiser sensors simply by product design.
But, I would have to purchase the additional WCM before I could actually test the range. (to determine if I would need to buy a "TPMS range extender" which is another 50 bucks)
All this makes the simplest and least expensive solution appear to be the most attractive... running the wire from the Cruiser indicator to the coach dash.
or... is my reasoning unsound somewhere? If so... I am always willing to do more legwork in an attempt to accomplish my goal as opposed to discussing reasons why something WON'T work. That's always my VERY last resort. :)
