fcooper's avatar
fcooper
TPMS-which works for mh & toad, then toad only?
I've been looking at the newer TPMS systems The TST 507 system, the Tire Tracker/Tire Minder/Hawkshead (same manufacturer) and the 508 system from eez rv products all seem to do the same basic pressure/temp reporting. Most owners report that these units work well.
I would like to be able to have a monitor that will work for the motorhome and toad while towing, and then be able to move the monitor into the toad when driving the toad without having to do a lot of reprogramming.
Do any of the units mentioned above allow this use of the monitor in the toad without reprogramming?
Thanks
Fred
  • Yes, Pressure Pro will operate that way. You can also easily move the control head from one vehicle to another with a second power source.
  • Not on you list but pressure pro will operate as you describe.
    Thanks
    Fred
  • I'm not aware of any TPMS that allows dropping the RV readings leaving only the toad to display. The TST at least, can do the reverse though, by dropping the toad readings when the toad is not brought along. In my previous toad, I installed a second TST monitor that was only programmed with the toad sensors, and just kept it in the toad. My current toad has the factory installed TPMS, so I have no need for the second display now.
