koda55
Jan 19, 2014Explorer
If you are mechanically inclined you can make your own. As mentioned above there are sites on here as to how to build your own.
I took the bolts out of the rear end and made a template. I took that to a place that had quarter inch steel and had them cut it out and they drilled the holes. I also had them make the bracket that attaches to the frame. I bought the cross bar at tractor supply. It is used as a steering leak on tractor. One end is fixed and the other is adjustable. Total cost was less then 100 dollars
38,782 PostsLatest Activity: Sep 10, 2026
