ichudov
Jan 18, 2016Explorer
Trace RC7 inverter OVERTEMP error in FREEZING weather
I have a Monaco Windsor 40PST class A motorhome with a Trace inverter.
I have a problem with this inverter, first, is that the fan makes a very annoying sound and does so at seemingly random times, regardless of whether the inverter is on and off. The fan noise goes away if the inverter is shutdown with the on/off button on the inverter body, however.
Secondly, when the weather turns to freezing temperatures, the inverter shuts down with "OTemp" error, meaning it overheated. (despite weather being unbearably cold at 0F). The load, of course, is nonexistent as the RV is mothballed.
After that everything goes to hell and batteries get completely drained and discharged.
I have a very understandable desire to keep my batteries in good shape and charged. I even plug my RV in nearly permanently, into shore 110v. I was hoping that it would keep my batteries charged.
However, this error means that I often come to the RV to find the batteries drained out, which leads to battery damage.
Has anyone experienced similar issues and what can I do to prevent such an upsetting turn of events.
I also do not frankly understand how a failure should lead to complete discharge of batteries. Common sense suggests that a failure should stop use of batteries.
Here's the picture:
http://igor.chudov.com/tmp/OTemp.jpg
Do not be fooled by high voltage reading on batteries, I was charging them externally.
I have my own suspicions, which is that the inverter fan is bad and needs to be replaced. But I wanted to see what others are thinking.
Thanks
Here's the picture:
Thanks
