peaches&cream wrote:
I also have a Tracvision Dish. I use the same receiver as I use at home. It is a HD receiver but the Tracvision will not produce HD on your tv. I have found the main thing when using my receiver is change the settings from Slimline to 18 inch round. Also change the setting from SWM to Multiswitch. Doing this I can manually tune my dish to sat. 101 and receive Direct TV stations.
Peaches& cream is correct on setting up the receiver I do the same thing with my home box. Make sure the satilite coax is hooked directly to the box and then let the satilite dish find the Direct TV satilite then program your receiver. i am assuming yours is a automatic roof mount Tracvision dish. It has always worked of me. Mine is an older dish so can't set it up for dual tv's. I watch all my recorded programs. it works well
