BruceLund
Jul 16, 2017Explorer
Trail Lite R-Vision Class B+
I can't find an answer to my question in all the videos I've searched so hopefully someone can help.
I have a hot water heater that, as far as I know, only runs on propane. When I turn on the switch at the control panel, the switch lights up red, and I can hear the flame ignite, and I do get hot water.
Many years ago I had a travel trailer. When I turned on the hot water heater switch, the red light came on, as it does now. When the water was completely heated, the light turned off.
On my Class B+ the light never goes off so I don't know when the water is fully heated. What I have been doing is setting a timer after I turn on the switch to see if I have enough hot water for my purpose. I've found that I have sufficient hot water after 15 minutes, but I would think they is something indicating when I can turn off the switch other than using a timer.
Thanks.
Thanks.
