Kidoo
Feb 20, 2015Explorer
Trailing arm repaired - Monaco Cayman 2003
Here is a picture of the repair done by my local big truck shop. Cost me $500.00.
First picture, you see the 1/2 inch plate, same on the other side. It is welded all the way on top and bottom, except for about an inch from the end, you can see the Welded Dot at the end to releive some stresses I beleive, this is how they do it on this type of repair. They had to unweld the top plate to insert the two additionnal plates than reweld it.
http://i651.photobucket.com/albums/uu235/Kidoo/P1100127_9006_zpsj9nqaagu.jpg
Here you see from the top, tww 1/2 inch plates fits right in. I do not think these will break where they use to, if the do somewhere else, I have ample of time to see it comming as it will not be in the hidden part.
http://i651.photobucket.com/albums/uu235/Kidoo/P1100122_9001_zpszewrfxgs.jpg
