hohenwald48
Dec 19, 2017Explorer
RLS7201 wrote:farmingdad wrote:
When I ran a 100 ft drop cord out to motor home to keep ref working the tranfer switch keeps clicking on an off
The transfer switch is in the normally closed position to shore power. It makes no difference what the voltage is. The transfer switch should not be trying to switch unless it sees voltage from the generator.
Are you sure it was the transfer switch clicking?
Richard
If you have a protector unit, like a built in Progressive unit, it could be disconnecting due to low voltage. When it connects/disconnects it make a thunk similar to the thunk of a transfer switch. (Probably uses a similar contactor internally)
38,782 PostsLatest Activity: Sep 10, 2026
