jyrostng
Aug 23, 2015Explorer
Deano56 wrote:jyrostng wrote:how would the linkage have anything to do with this? I am thinking about the vacuum too
If it has a modulator, check the vacuum line to it.
also check the kick down linkage or cable.
it depends on the transmission, some with a kickdown cable , the cable sets the pump pressure off throttle position. on some, if it's set wrong it can burn the transmission up. I don't remember you saying what you have.
