et2
Oct 09, 2016Explorer
If it's a Allison 3000 or 4000 transmission and you have Transynd then it's 5 years or unless your oil monitor system indicates otherwise. You should be able to check the following off the Allison transmission selector key pad.
OL - oil level ( two minute delay after stopping in idle engine on) press up and down arrows at the same time
OM - maintenance required (change) - press arrow key again while in above mode and it will scroll to one of the following and indicate, "OK" or a issue
FM - filter maintenance
TM - maintenance
If you read your owners manual it's all stated. If not your can download a Allison manual on-line by doing a search.
If you see a wrench in that display you have something needing to be addressed. You really need to get a manual
TM - maintenance
38,768 PostsLatest Activity: Nov 21, 2015
