rgatijnet1
Oct 09, 2016Explorer III
usersmanual wrote:rgatijnet1 wrote:usersmanual wrote:rgatijnet1 wrote:
Here you go. Just answer the questions on this Allison site: Service intervals
this is useless for a MH.
Some people consider a MH as severe duty in which case this give good service intervals. If they recommend a certain schedule for a commercial vehicle you can bet that it is more than sufficient for a MH. Thanks so much for your valuable input. :B
whatever your happy with I don't see it as a useable tool for a MH that only goes 6000(eg) miles in a year.
A MH is far far removed from severe duty that I know
295 oil is good for 300K there is the 5 year rule if your into time factors(iam not) I do believe the oil filters first time around is in the 50K mile range
Had you run the numbers in the link that I gave it would have recommended 300,000 miles OR FOUR years if they had 295 fluid and 75,000 miles or THREE years for the filter change. I'm guessing the OP does not have an owners manual or he could have looked this all up himself.
38,768 PostsLatest Activity: Nov 21, 2015
