map40's avatar
map40
Transmission oil change due to time?
I'm buying an Alfa with a C7 and an Allison 3000. The tranny had an oil change 4 years and 25k miles ago. Do you change the trans fluid due to time?
    Here is the right way to change the trans oil, and use TranSynd TES 295 Fluid
    https://www.youtube.com/watch?v=_5PbOg9x4qo
    JR45
  • One of the smart things you can do when you buy a car, boat or RV is change all the fluids.
  • FWIW, I would change the transmission fluid. Then you know when it was changed, the type of fluid used and have a baseline for future maintenance.
  • I'm confused, nothing new. But putting oil in your transmission? Thought you put transmission fluid in it.
