TC_Z's avatar
TC_Z
Transynd ??
The owner's maunal for our 2007 Winn Voyage 38J gas engine with Allison 6-speed transmission says to use Transynd transmission fluid. I have checked local auto parts and Walmart and don't find it. Has this been replaced by a newer fluid? If so which one?
  • wolfe10 wrote:
    Charlie D. wrote:
    If your unit came with Transynd it should not require changing unless you have some kind of transmission failure or it becomes contaminated.
    And, I would suggest that if this is the OE fluid and therefore at least 12 years old, it is well worth changing (along with the filter).
    You are sooooo correct:)
