wincrasher65 wrote:
FWIW, from RVsafety.com:
In June of 2008, the U.S. Department of Transportation’s (DOT) National Highway Transportation Safety Administration (NHTSA) adopted revisions to the regulations in 49 CFR Part 571 to require separate and specific RV weight labels. This ruling superseded any prior RVIA requirements and replaced the 2000 RVIA labeling system (see below).
The NHTSA label requirements include the following additional key terms:
OCCC (Occupant and Cargo Carrying Capacity) (for Motorized RVs only): This figure states the maximum allowable weight of all occupants (including the driver), plus the weight of all food, tools, full fresh water tanks, full LP-Gas tanks and personal belongings. The maximum allowable weight of passengers is based on the number of seat belted positions in the motorized RV. The regulation also states that the “tongue weight of towed trailer counts as cargo.”
CCC (Cargo Carrying Capacity) (for Towable RV’s only): This figure states the maximum allowable weight of all cargo, including all food, tools, full fresh water tanks, full LP-Gas tanks and personal belongings.
Load Carrying Capacity Reduced: The regulation also requires dealers to state on an amended or additional label the total amount (in pounds and kg) that additional options or changes to the RV have decreased the OCCC or CCC. The amount stated is limited to the total weight of all additions or changes made by the dealer ‘prior to the first sale’ that are the ‘lesser of 1.5% of the GVWR or 100 pounds’.
LP-gas, is no longer in the regulations. Instead the term "propane" is used. Also the weight of the full propane tank is counted in the UVW, not in OCCC. Here is a direct quote
If the vehicle is a motor home and is equipped with a propane supply, the weight of full propane tanks must be included in the vehicle's unloaded vehicle weight. 49 CFR 571.110 as found on
www.law.cornell.eduTom
