Mr_Mark1
Mar 01, 2017Explorer
Mr. Quint,
If you are going to be in that cold of weather, it's best to have your fresh water tank FULL. It will help in keeping the basement from freezing as that much water will be a 'heat sink' absorbing the cold.
I would think that a 20 amp connection will be enough for you to run the furnace fans. I also would imagine that you would put the fridge on propane.
Good luck,
MM.
Good luck,
MM.
