rgatijnet1
Mar 01, 2017Explorer III
If you are concerned about the water lines freezing in the wet bay, we use a 11-150 watt INCANDESCENT light bulb in that bay in a shielded holder like a shop trouble light. This has kept our wet bay from freezing even in temps below zero. Running your water heater and furnace on LP should keep the rest of the coach comfortable and safe from freezing. An electric blanket is nice and it uses very little power.
The biggest issue can come from condensation forming on your inside window surfaces, like the windshield. You may need to put towels at the base to soak up any condensation if you don't have enough AC power available to run fans to blow on the windshield.
