JimM68 wrote:
Thanks for the reply. I cheat, got a forklift at work that is just waiting to put it on the roof and take the old one off.
I'll run dicor around the outside and over the screw heads.
You used it underneath too?
You MUST run a bead of Dicor under the antenna around the outside ring of the base so the antenna mounting plate is sitting in a bed of Dicor. After you screw it down you will then run a second bead of Dicor on top that will cover the edges and the screws. Preventing moisture from getting into the open base area is critical to the successful operation of the Trav'ler for years to come.
