DSDP Don wrote:
Cables- You should have cables that are already there and run through the roof with a cover plate.
Wingegard provides 2 RG6 cables. However, there are 3 RG6 connections (labeled A, B, and C).
I suggest attaching a 3rd RG6 cable to that other connector & then running all 3 RG6 cables into your RV.
Though you only may need one or two of these RG6 cables now, you might need all three in the future. I did. And shlepping up to the roof to run that 3rd cable was a PITA -- would have been much easier if I had run all three in the first place.
