jeremywatco
Apr 01, 2014Explorer
Trimetric Routing
Good Evening,
Just received my new Trimetric 2025-RV and am itching to get it installed. I have a few questions:
1. Does the shunt have to be mounted securely? There is plenty of room on top of my batteries to just set it there and I feel once I get all the wires connected and tied it wont move around much.
2. The main question.. how the heck do I route wires through my coach LOL. Ideally I want it next to my tank monitors however after taking them out and trying to look behind it seems as if the existing cables from from the center of the coach all the way forward to the very front and then down and back to the battery bank.
It seems I'd have to disassemble quite a bit of the interior just to run the single cat5 cable I want to run.
I am not 100% certain this is the case though. The cabinet panel I need to remove to see the back side is glued down. Any thoughts on getting into the cabint. Here is a picture of the monitor area:
i just cant figure it out.
Another option is right below the entry switches. My only concern is, would the kids mess with it down there also how much interaction do you have with these meters. Do you leave them on a certain display and just glance every once in a while or do you constantly use the buttons? Option 2 is across the doorway from option 1 but the batteries are right under that step.
Here is option 2:
DOes fleetwood publish schematics of how they route wires? its a 2014 Fleetwood storm
Here is option 2:
