bullydogs1
Aug 19, 2014Explorer II
The trombetta solenoid closes when either the emergency switch is engaged or the generator charges the chassis batteries or the alternator from the chassis is charging the house batteries..The one they use from the factory goes due to corroded connections...replace it with an updated one, (it has a suffix of -20 on it instead of -10)...and then I bet it will work again as it should..right now it looks like it isn't closing to charge the bridge up.
38,782 PostsLatest Activity: Sep 02, 2026
