YC_1
Aug 19, 2014Nomad
I own the same rv and am intimately familiar with the solenoid and the operation of the BIRD circuit,.
If you are saying that the voltage on one of the large terminals is lower than the other terminal when there is voltage on the purple wire and 0 volts on the other little terminal then the solenoid is shot and is very common. I have replaced mine twice. I took mine apart to see what the issue was. Green and gooey inside mine. It was only a year old.
They get very hot to the touch so be careful if it has been plugged in a long time.
Order a new one and get the one with silver contacts for better life.
If you want to read all about it for a couple of days I can send you to some very long threads on the subject.
It is a simple dumb relay. Works or does not work. Simple.
