crasster
Apr 13, 2018Explorer II
ACDNate wrote:donn0128 wrote:
12 volt circuits will have fuses NOT breakers. Breakers will all be 120VAC
Find your fuse panel. Check all fuses with an ohm meter.
Go to the first light fixture closest to the switch. Assuming the switch has power on the on side.
Take the fixture down and look. The wiring will be daisy chained and quite possibly a wife nit has come loose or a wire has pulled out killing the lights.
This coach has 12v push button "breakers" in a panel next to the 120v regular breakers. The chasis 12v system has both traditional fuses/relays in one panel and then more push button breakers.
Make sure the buttons are working too as I've seen several flimsy ones. Continuity with a meter should do.
38,763 PostsLatest Activity: Dec 05, 2025
