Gridley
Aug 06, 2023Explorer
That was a good suggestion to check the Circuit Breakers. The were all OK.
I tried a Soft Reset of the Inverter with no change in symptoms. Then I tried a Hard Reset of the Inverter again with no change in symptoms.
As of now, the Inverter seems to work fine. It will run the Fridge and the Microwave and the TV's. But the Outlets, both normal and GFI are dead on the Inverter. On Shore power the Charger charges the batteries fine and the Fridge, Microwave, TV's etc work fine. Also the non-GFI outlets work on Shore power.
So everything is OK except the outlets. Outlets work on Shore power but not on Inverter. GFI-outlets don't work on Shore power or Inverter.
I'm at a loss as to what it could be unless there is something wrong with the Inverter. It is in a 35' Diesel Class A RV, a Tiffin Allegro Red 33AA.
Thank you for your help so far.
Tim
Tim
