GridleyExplorerAug 05, 2023trouble with ac outlets in Allegro Red 33My RV was connected to shore power. I was vacuuming with a shop vac plugged into a GFI outlet in the RV. Then the power to the vacuum just stopped. Nothing in the GFI outlets. The non-Gfi outlets we...Show More
AllegroDNomadAug 06, 2023Do you have a volt meter? Have you verified the output? You should call Magnum.
Related Content2012 ALLEGRO TIFFINNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problem
