LVJ58
Aug 27, 2014Explorer
You need to check to see if voltage is getting to the solenoid air valve, if it isn't you have an open somewhere in the circuit. If you do have voltage, then most likely the solenoid valve is faulty, or sometimes the inside valve assembly gets corroded from moisture in the system.
Had a problem with mine and I disassembled the valve, cleaned it out, it then worked.
Good luck and let us know the fix..
