holstein13
Jul 17, 2015Explorer II
I've got the true induction "double burner" factory installed by Newmar in my coach. I like it but would caution you to not waste your money on a double burner. Unfortunately, only one burner will work at full temperature. If you raise the other burner, it lowers the first burner by one level for each level you raise the second one. At best, you can get both burners at half the wattage. Kinda useless for a double burner, don't you think?
I actually bought a single burner that I plug into the wall and place on top of the second burner when we need to cook two pots.
And for those of you who may believe that your True Induction double burner gives you 100% power on both burners simultaneously, I suggest you look at the manual or simply try it yourself.
38,782 PostsLatest Activity: Sep 10, 2026
